External battery 5V / 12000mAh USB output for 3 Raspberry Pi / Pi 2
These two modules form an external battery for Raspberry Pi. Delivering a voltage of 5V and a capacity of 12000mAh thanks to no less than 2 batteries (sold separately), this battery will allow you to power your RPI for long hours, and therefore to move it, even outdoors.
3.0 / 5
Reference : 13350
25,90 €tax incl.
21,58 € tax excl.
Raspberry Pi battery
Emergency block battery 5V 12000mAh USB output for Raspberry Pi
Batterie externe 5V 12000mAh USB pour Raspberry Pi
These two modules form an external battery for Raspberry Pi. Delivering a voltage of 5V and a capacity of 12000mAh thanks to no less than 2 batteries (sold separately), this battery will allow you to power your RPI for long hours. In addition, a battery power supply provides the Raspberry with a clean power supply, allowing for quality audio playback.
On the connector side, the module has two 5V outputs on USB-A. These can be offset using two 2-pin connectors, allowing modular integration. It is also possible to charge the batteries directly without using an external charger via the Micro USB-B or Lightning connector. Finally, the card has an integrated on/off button but also a 2-pin connector to add a button and thus benefit once again from new integration possibilities.
As the battery has two USB-A connectors, it is also possible to connect another module or SBC, checking beforehand the voltage and current that the latter requires (and without exceeding 2.2A for both outputs).
Note: 18650 batteries and Raspberry Pi are sold separately.
Product typeEmergency block for Raspberry Pi
RPI 4 SupportYes (requires not-included USB-C cable)
Battery slots2
Battery typeLi-Ion 18650
Max capacity12000mAh
Output voltage5V
Max discharge current (2 combined outputs)2.2A
Voltage / Discharge current5V 1A
Charging connectorMicro USB-B
Lightning
Power supply output2 (via USB-A or 2 pins connectors)
Package1x Power supply module
1x Battery module
Screws and spacers
BATTERIE POUR RASPBERRY PI
Un peu déçu....pas de notice passe encore mais la visserie ne correspond pas aux entretoises donc obligé de l'utiliser en déporté...Et ce serait bien de proposer un boitier ...Diodes de charge un peu trop aveuglantes....
Mais à part çà, l"alimentation fonctionne bien
This review has been posted for External battery 5V / 12000mAh USB output for 3 Raspberry Pi / Pi 2
These two modules form an external battery for Raspberry Pi. Delivering a voltage of 5V and a capacity of 12000mAh thanks to no less than 2...
