IAN CANADA STATIONPI Pre-assembled adapter PCB for Raspberry Pi and Audio Modules
4.0 / 5
Reference : 14868
59,90 €tax incl.
49,92 € tax excl.
IanCanada StationPi
The StationPi from Ian Canada is a pre-assembled PCB with all the connectors required to easily connect your Raspberry Pi (or other GPIO compatible digital audio source) to a DAC or digital transport module. Designed to be easily mounted in a housing, it is an ideal solution to move forward to a finished product stage once satisfied with your prototypes.
The PCB has two power connectors and allows several integration scenarios with regard to the power supply of the installed modules (shared or separate power supply). A location even allows to solder two capacitors (optional) to add filtering capacities directly integrated into the assembly.
Shielding
The support is delivered with shielding plates to compartmentalize the digital and analog sections if necessary. This not only gives a very robust rendering but also helps reduce pollution related to electromagnetic noise.
In the photo above a Raspberry Pi (not delivered) and a FifoPi (not delivered) mounted on the StationPi.
Pinout
Dimensions and spacings
Excellent produit !!
Excellente station d’accueil pour qui veut isoler galvaniquement son Raspberry de son Dac ou Recloker. En ce qui me concerne j’ai fait aussi l’acquisition du Recloker de la même marque et cette station d’accueil m’a été fort utile. Le produit comme tous les produits de la marque sont de très bonne facture, cela respire la qualité malgré un prix un peu élevé.
This review has been posted for IAN CANADA STATIONPI Pre-assembled adapter PCB for Raspberry Pi and Audio Modules
