Male / Female Extension GPIO 40 Pins Ribbon Cable for Raspberry Pi 2 / 3 10cm
This ground cable allows the 40-pin GPIO connector to be offset from a Raspberry Pi. Especially useful for a DIY mounting in which you want to place a module next to your Raspberry Pi rather than above it for example.
Reference : 13630
3,50 €tax incl.
2,92 € tax excl.
GPIO Extension Cable
Male / Female Extension GPIO 40 Pins Ribbon Cable for Raspberry Pi A / B 10cm
Nappe d'Extension GPIO Mâle / Femelle 40 Pins pour Raspberry Pi 10cm
This ground cable allows the 40-pin GPIO connector to be offset from a Raspberry Pi 2 or 3. Especially useful for a DIY mounting in which you want to place a module next to your Raspberry Pi rather than above it for example.
This cable is not compatible with Raspberry Pi A and B.
Product typeGPIO extension ribbon cable
CompatibilityRaspberry Pi 2 / Raspberry Pi 3
Length10cm
Number of pins2x20 pins
Connectors genreMale / Female
Pitch2.54mm
Length (m)0.1
ShieldingNo
Section (mm²)N/A
ConnectorGPIO
This ground cable allows the 40-pin GPIO connector to be offset from a Raspberry Pi. Especially useful for a DIY mounting in which you want to...
