We offer this Micro SD card with the Moode Audio operating system pre-installed and configured so that you can use your network drive as soon as you receive it. All you have to do is insert the card into your device and enjoy your music thanks to a powerful and intuitive system.
We offer multiples version of MoOde. Each has been optimized to deliver best results with a specific device. Please select the device you want to use with MoOde below :
Custom MOODE Audio pre-installed 8Go SDCard for Raspdac / Rasptouch products
We offer you, in order to be able to use your network drive as soon as you receive it, this Micro SD card with the Moode Audio operating system pre-installed and configured. RaspDac and RaspTouch network drives require several changes to the moOde image to take advantage of all features. The version provided here is ready for use.
Moode Audio is an Open Source operating system designed to play audio files with the best playback.
It works on Raspberry Pi and is therefore also perfect to work on RaspTOUCH and RaspDAC.
Associated with one of our devices, it will become a real media player, remotely controllable via a mobile phone, a computer or a tablet, via the dedicated web application or for the Rasptouch directly via the touch screen of the latter.
Connected to your network, it will then become possible to play music file from your NAS, listen Internet radios, or stream your music to DLNA/Airplay from any device also connected to your network.
If we recommend Moode Audio it is because this system gathers all the characteristics necessary to make an excellent audiophile and autonomous player.
It is both powerful and powerful, intuitive, accessible and visually worked . In addition, it offers many features and extensions, allowing it to evolve according to your desires.
All your music
A single player for all your music: MP3, FLAC, WAV, AAC, ALAC, DSD and much more, moOde is compatible with most file formats. In addition, it supports DNLA, UPnP, Airplay, Spotify and web radios.
Audiophile quality
Moode Audio is a true audiophile HiFi player, enabling bit-perfect playback, DSD support and high sampling rates for uncompromising audio quality.
Your music, your listening
Why just listen to your music on your computer? By connecting a moOde device to your audio system, you no longer need to lift off the couch to listen to your music from any connected device.
Open Source
Moode Audio is totally Open Source, developed by an active team and an important community. Updates and patches are therefore frequent and it is easy to find help on the forums in case of problems.
Affordable hardware
Moode Audio has been designed to work first with the Raspberry Pi. Thus, by combining this material with Moode Audio, you obtain an effective, efficient and complete solution at low cost.
While there are many OSes dedicated to playing audio files, Moode Audio offers a pure and effective interface. Moreover, the web app allowing system control is totally responsive. It adapts to all your devices - computer, telephone, tablet, TV - allowing you to act on the reading of your files just as easily, whatever your equipment.
The image installed on this board includes several modifications to take advantage of the components used on Raspdac and Rasptouch.You can thus use your reader without prior technical manipulations which can be dissuasive to the néophites.
The main changes are :
As these changes are related to the moOde and kernel versions, we strongly recommand to avoid automatic updates and official updates. However, we will regularly upload an updated version of the image.
moOde | |
OS type | Open Source Audiophile player |
Compatible hardware | Raspdac/Rasptouch ES9023 / ES9028Q2M / ES9038Q2M |
Supported network protocols | UPnP DLNA Airplay |
Plugins | Many available plugins : Spotify, Web Radios, Facebook, Youtube... |
Bit-Perfect support | Yes |
Supported file formats | FLAC, ALAC, AAC, VORBIS, MP3, DSD, etc. |
DoP Support for non compatibles with Direct DSD peripherals | Yes |
Others features | Playlist creation and edition Multilang Alarm and standby ... |
Micro SD card | |
Storage capacity | 8Go |
Class | 10 |
Reading speed | 48Mb/s |
Writing speed | 12Mb/s |
Accessories | SD Adapter |
