On / Off Switch for Raspberry Pi with Multimedia IR Remote Control and Screen
Nanosound offers with its small module Pi Switch Cap a simple way to control the switching on and off of your Raspberry, without having to plug or unplug the power cable each time. Thus, the module integrates an On / Off button which, by simple pressure will switch on or off your Raspberry Pi. But better than that, the module integrates an IR LED, a remote control and a screen. It is therefore possible to directly control your Raspberry remotely and view playback information (music playback, sampling rate and parameters). In addition, the remote control, specially designed for multimedia use for easy control of your device and playback of your files.
Installation is very simple since it is enough to connect the Pi Switch Cap to the Raspberry, without cable and without soldering or other tool, to be able to benefit from the functionalities of the module. Concerning the screen, 4 welding points will be enough to mount it on the Pi Switch Cap
On the software side, the Nanosound module is compatible with Kodi for multimedia use and with Volumio for purely audio use.
As far as hardware is concerned, it should be noted that the offer has 3 I2C ports. These allow the Pi Switch Cap to be enhanced with optional modules (not supplied) such as an OLED display, a temperature/humidity sensor (SENSIRION SHT31) or a pressure sensor (BOSCH BMP180).
You will find by following this link a tutorial to install and use the software solution Volumio.
The Pi Switch Cap is based on an ATtiny85 microcontroller. This can be removed to be reprogrammed according to your needs. Source codes ATtiny Software and Shutdown Script being Open Source, they will allow you to modify them for example to use other remote controls.
Attention: These manipulations are reserved for expert persons. Improper handling will cause the unit to malfunction and void the warranty.
OS Compatibility | Volumio Kodi |
Package | 1x Pi Switch Cap 1x Multimedia Remote Control 1x OLED Screen |
Dimensions du module Pi Switch Cap | 56 x 33mm |
Dimensions totales de l'écran OLED | 29 x 27mm |
Dimensions affichage OLED | 0.96" |
