SUPTRONICS X830 SATA Adapter for HDD 3.5" on Raspberry Pi 3 / 3B / 3B+
With this X830 module it becomes possible to associate a hard disk to your Raspberry Pi to offer a storage capacity up to 10TB.
Reference : 13269
43,90 €tax incl.
36,58 € tax excl.
SUPTRONICS X830
SATA Adapter for HDD on Raspberry Pi
X830 Adaptateur SATA pour HDD sur Raspberry Pi
While the Raspberry Pi is an extremely versatile SBC, it does not have a SATA connector for a hard drive. With the X830, this problem is solved, since the module comes directly under the Raspberry Pi and gives it a SATA connection. It is thus possible to offer a large storage capacity to your RPI, up to 10TB, while having a very good transfer speed thanks to the USB 3.1 to SATA 6Gb/s controller.
Important : RPI Power supply
The X830 module powers the Raspberry Pi. Do not power the RPI directly via his Micro USB plug. To power the Raspberry Pi simply connect the power cable (2 wires, red and black) as shown below.
Product typeSATA Adapter for Raspberry Poi
Hardware compatibility
Raspberry Pi 1 Model B+
Raspberry Pi 2 Model B
Raspberry Pi 3 Model B / B+
NOT COMPATIBLE PI 4
Software compatibilityAll OS for Raspberry Pi
Hard Drive compatibilitySATA 3.5" HDD up to 10TB
Connectors1x USB-A 3.0
1x XH 2.54mm 3 pins (Power output)
1x PH 2.0mm 4 pins (Power switch)
Power supply14~40VDC 3A via Jack DC 5.5/2.5mm
Dimensions155.8 x 118mm
Package1x X830 Board
1x USB Jumper
1x Male / Male USB-A 3.0 Cable
1x Power supply connection cable
4x M2.5 x 12mm spacers
8x M2.5 x 6mm screws
8x Vis M3 x 8mm screws
4x M3 x 30mm spacers
