livré préchargé et configuré tel que décrit. Parfait. Reste juste a voir comment sauvegarder la carte (clonage) pour refaire une carte en cas de panne.
We offer this Micro SD card with the Volumio operating system pre-installed and configured so that you can use your network drive as soon as you receive it. All you have to do is insert the card into your device and enjoy your music thanks to a powerful and intuitive system.
Depending on the device you have, the image will not be exactly the same. It has to be suited for your hardware specifics. Please use the button below to pick the device you intend to use in order to run Volumio.
Carte Micro SD 8Go avec Image personnalisée Volumio
We offer you, in order to be able to use your network drive as soon as you receive it, this Micro SD card with the Volumio operating system pre-installed and configured. RaspDac and RaspTouch network drives require several changes to the Volumio image to take advantage of all features. The version provided here is ready for use.
Volumio is an Open Source operating system designed to play audio files with the best playback.
It works on many devices and is particularly suitable for SBC (Single Board Computer) such as Raspberry Pi. It is therefore also perfect to work on RaspTOUCH and RaspDAC.
Associated with one of our devices, it will become a real media player, remotely controllable via a mobile phone, a computer or a tablet, via the dedicated web application or for the Rasptouch directly via the touch screen of the latter.
Connected to your network, it will then become possible to stream your music to DLNA/Airplay from any device also connected to your network.
If we recommend Volumio it is because this system gathers all the characteristics necessary to make an excellent audiophile and autonomous player.
It is both powerful and powerful, intuitive, accessible and visually worked . In addition, it offers many features and extensions, allowing it to evolve according to your desires.
All your music
A single player for all your music: MP3, FLAC, WAV, AAC, ALAC, DSD and much more, Volumio is compatible with most file formats. In addition, it supports DNLA, UPnP, Airplay, Spotify and web radios.
Audiophile quality
Volumio is a true audiophile HiFi player, enabling bit-perfect playback, DSD support and high sampling rates for uncompromising audio quality.
Your music, your listening
Why just listen to your music on your computer? By connecting a Volumio device to your audio system, you no longer need to lift off the couch to listen to your music from any connected device.
Open Source
Volumio is totally Open Source, developed by an active team and an important community. Updates and patches are therefore frequent and it is easy to find help on the forums in case of problems.
Affordable hardware
Volumio has been designed to work first with the Raspberry Pi and other SBCs, not very powerful but very affordable. Thus, by combining this material with Volumio, you obtain an effective, efficient and complete solution at low cost.
While there are many OSes dedicated to playing audio files, Volumio is probably the one with the most intuitive and aesthetic interface.Moreover, the web app allowing system control is totally responsive. It adapts to all your devices - computer, telephone, tablet, TV - allowing you to act on the reading of your files just as easily, whatever your equipment.
The image installed on this board includes several modifications to take advantage of the components used on Raspdac and Rasptouch.You can thus use your reader without prior technical manipulations which can be dissuasive to the néophites.
The main changes are :
As these changes are related to the Volumio and kernel versions, we strongly recommand to avoid automatic updates and official updates. However, we will regularly upload an updated version of the image.
Volumio | |
OS type | Open Source Audiophile player |
Compatible hardware | Raspdac/Rasptouch ES9023 / ES9028Q2M / ES9038Q2M |
Supported network protocols | UPnP DLNA Airplay |
Plugins | Many available plugins : Spotify, Web Radios, Facebook, Youtube... |
Bit-Perfect support | Yes |
Supported file formats | FLAC, ALAC, AAC, VORBIS, MP3, DSD, etc. |
DoP Support for non compatibles with Direct DSD peripherals | Yes |
Others features | Playlist creation and edition Multilang Alarm and standby ... |
Micro SD card | |
Storage capacity | 8Go |
Class | 10 |
Reading speed | 48Mb/s |
Writing speed | 12Mb/s |
Accessories | SD Adapter |
Average votes 5.0 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Christophe D.
Ron P.
Patrick B.
Laurent T.
