AECO ARP-1512G RCA Connectors Tellurium Copper Gold Plated Ø11mm (Set x4)
These high-quality aeco ARP-1512G RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are made of high-purity tellurium copper with 10µ gold plating, ensuring both excellent conductivity and perfect resistance to oxidation.
3.0 / 5
Reference : 18025
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 24-04-2025.
aeco ARP-1512G
These high-quality aeco ARP-1512G RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are made of high-purity tellurium copper with 10µ gold plating, ensuring both excellent conductivity and perfect resistance to oxidation. The insulation is made of glass-fibre reinforced nylon and the outer shell is made of stainless steel to ensure high durability. The connectors have a structure that allows them to be completely dismantled for easy soldering. They also accept cables up to Ø11.5mm in diameter, which are held in place by two screws.
Product typeMale RCA connectors
Contacts materialHigh purity tellurium copper
Contacts platingGold 10µ
Contacts resistance< 0.3mΩ
Insulation materialFibreglass-reinforced nylon
POM
Shell materialStainless steel
Max cable diameterWith reducer: Ø9mm
Without reducer: Ø11.5mm
Total dimensionsØ13.9*45.7mm
ColorSilver
Package4 connectors (2 with red ring, 2 with white ring)
Max cable diameter (mm)11.5
Mounting typeTo weld
ConnecticMale
Contacts Material (Connector)Tellurium Copper
Un petit compliqué à souder .
Sinon le son un propre et détaillé
This review has been posted for AECO ARP-1512G RCA Connectors Tellurium Copper Gold Plated Ø11mm (Set x4)
These high-quality aeco ARP-1512G RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts...
