AECO ARP-1512R RCA Connectors Tellurium Copper Rhodium Plated Ø11mm (Set x4)
These high-quality aeco ARP-1512R RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are made of high-purity tellurium copper with rhodium plating, ensuring both excellent conductivity and perfect resistance to oxidation.
Reference : 18026
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 24-04-2025.
aeco ARP-1512R
These high-quality aeco ARP-1512R RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are made of high-purity tellurium copper with rhodium plating, ensuring both excellent conductivity and perfect resistance to oxidation. The insulation is made of glass-fibre reinforced nylon and the outer shell is made of stainless steel to ensure high durability. The connectors have a structure that allows them to be completely dismantled for easy soldering. They also accept cables up to Ø11.5mm in diameter, which are held in place by two screws.
Product typeMale RCA connectors
Contacts materialHigh purity tellurium copper
Contacts platingRhodium
Contacts resistance< 0.3mΩ
Insulation materialFibreglass-reinforced nylon
POM
Shell materialStainless steel
Max cable diameterWith reducer: Ø9mm
Without reducer: Ø11.5mm
Total dimensionsØ13.9*45.7mm
ColorSilver
Package4 connectors (2 with red ring, 2 with white ring)
Max cable diameter (mm)11.5
Mounting typeTo weld
ConnecticMale
Contacts Material (Connector)Tellurium Copper
Connecteurs intelligents
Première fois que je tombe sur des connecteurs qui se "plugs" grace à la bague interne et qui se vissent pour maintenir une connection ferme sur le RCA femelle. Mais l'ingéniosité réside dans la conception complétement éclatée qui permet des soudures propres, faciles sans endommager le connecteur. Il faut prendre le temps de comprendre le montage, mais ce sont des connecteurs performants, solides et très esthétiques.
This review has been posted for AECO ARP-1512R RCA Connectors Tellurium Copper Rhodium Plated Ø11mm (Set x4)
These high-quality aeco ARP-1512R RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts...
