AECO ARP-1512S RCA Connectors Tellurium Copper Silver Plated Ø11mm (Set x4)
These high-quality aeco ARP-1512S RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are made of high-purity tellurium copper with 120µ silver plating, ensuring both excellent conductivity and perfect resistance to oxidation.
Reference : 18027
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 24-04-2025.
aeco ARP-1512S
These high-quality aeco ARP-1512S RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are made of high-purity tellurium copper with 120µ silver plating, ensuring both excellent conductivity and perfect resistance to oxidation. The insulation is made of glass-fibre reinforced nylon and the outer shell is made of stainless steel to ensure high durability. The connectors have a structure that allows them to be completely dismantled for easy soldering. They also accept cables up to Ø11.5mm in diameter, which are held in place by two screws.
Product typeMale RCA connectors
Contacts materialHigh purity tellurium copper
Contacts platingSilver 120µ
Contacts resistance< 0.3mΩ
Insulation materialFibreglass-reinforced nylon
POM
Shell materialStainless steel
Max cable diameterWith reducer: Ø9mm
Without reducer: Ø11.5mm
Total dimensionsØ13.9*45.7mm
ColorSilver
Package4 connectors (2 with red ring, 2 with white ring)
Max cable diameter (mm)11.5
Mounting typeTo weld
ConnecticMale
Contacts Material (Connector)Tellurium Copper
2 reviews
Best quality price RCA to date
Awesome plugs, soundwise, looks and pricing
From now on, I will only use these
Cannot be beaten for the price and they look gorgeous
This review has been posted for AECO ARP-1512S RCA Connectors Tellurium Copper Silver Plated Ø11mm (Set x4)
Une horreur à monter
La bague qui tient les connecteurs à souder s'ouvre et c'est un galère sans nom une fois soudé pour tout remonter... Les pires fiches que j'ai pu utiliser !
Leur structure est en effet complexe mais elle est au service de la qualité de conductivité et connexion. Un schéma et un éclaté complet sont visibles sur la fiche permettant de juger de la complexité de mise en œuvre.
These high-quality aeco ARP-1512S RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts...
