AECO ARP-4045G RCA Connectors Tellurium Copper Gold Plated Ø10mm (Set x4)
These high-quality aeco ARP-4045G RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are made of high-purity tellurium copper with 10µ gold plating, ensuring both excellent conductivity and perfect resistance to oxidation.
Reference : 18028
75,90 €tax incl.
63,25 € tax excl.
Shipping date: 24-04-2025.
aeco ARP-4045G
These high-quality aeco ARP-4045G RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are made of high-purity tellurium copper with 10µ gold plating, ensuring both excellent conductivity and perfect resistance to oxidation. The insulation is made of glass-fibre reinforced nylon with a star shape for a firm connection, and the outer shell is made of brass for durability. The connectors have a short format with a reduced conductor size, limiting resistance, capacitance and inductance sensitivity during signal transmission. They also accept cables up to Ø10.5mm in diameter, which is held in place by a screw.
Product typeMale RCA connectors
Contacts materialHigh purity tellurium copper
Contacts platingGold 10µ
Contacts resistance< 0.3mΩ
Insulation materialFibreglass-reinforced nylon
POM
Connectors shell materialBrass
Max cable diameterWith reducer: Ø8.5mm
Without reducer: Ø10.5mm
Total dimensionsØ13.7*46.4mm
ColorSilver
Quantity4 connectors (2 with red ring, 2 with white ring)
Max cable diameter (mm)10.5
Mounting typeTo weld
ConnecticMale
Contacts Material (Connector)Tellurium Copper
These high-quality aeco ARP-4045G RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts...
