These high-quality aeco ARP-4045S RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are made of high-purity tellurium copper with silver 120µ plating, ensuring both excellent conductivity and perfect resistance to oxidation. The insulation is made of glass-fibre reinforced nylon with a star shape for a firm connection, and the outer shell is made of brass for durability. The connectors have a short format with a reduced conductor size, limiting resistance, capacitance and inductance sensitivity during signal transmission. They also accept cables up to Ø10.5mm in diameter, which is held in place by a screw.
Product type | Male RCA connectors |
Contacts material | High purity tellurium copper |
Contacts plating | Silver 120µ |
Contacts resistance | < 0.3mΩ |
Insulation material | Fibreglass-reinforced nylon POM |
Connectors shell material | Brass |
Max cable diameter | With reducer: Ø8.5mm Without reducer: Ø10.5mm |
Total dimensions | Ø13.7*46.4mm |
Color | Silver |
Quantity | 4 connectors (2 with red ring, 2 with white ring) |
Max cable diameter (mm) |
Mounting type |
Connectic |
Contacts Material (Connector) |
Contacts Plating (Connector) |
