AECO ARP-4055 RCA Connectors Pure Silver Ø10mm (Set x4)
These high-quality aeco ARP-4055 RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are 99.9% pure silver, ensuring perfect conductivity.
Reference : 18031
189,00 €tax incl.
157,50 € tax excl.
Shipping date: 23-04-2025.
aeco ARP-4055
These high-quality aeco ARP-4055 RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts are 99.9% pure silver, ensuring perfect conductivity. The insulation is made of glass-fibre reinforced nylon with a star shape for a firm connection, and the outer shell is made of brass for durability. The connectors have a short format with a reduced conductor size, limiting resistance, capacitance and inductance sensitivity during signal transmission. They also accept cables up to Ø10.5mm in diameter, which is held in place by a screw.
Product typeMale RCA connectors
Contacts materialSilver (purity: 99.9%)
Contacts resistance< 0.3mΩ
Insulation materialFibreglass-reinforced nylon
POM
Connectors shell materialBrass
Max cable diameterWith reducer: Ø8.5mm
Without reducer: Ø10.5mm
Total dimensionsØ13.7*46.4mm
ColorSilver
Quantity4 connectors (2 with red ring, 2 with white ring)
Max cable diameter (mm)10.5
Mounting typeTo weld
ConnecticMale
Contacts Material (Connector)Silver
These high-quality aeco ARP-4055 RCA connectors, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts...
