ATAUDIO Q8RF Female RCA Connector Ø7.5mm (The pair)
These gold-plated RCA connectors are designed to provide good conductivity and resist oxidation. The conductors are made of high purity copper for a very good transmission of the sound signal. In addition, their shell provides effective protection against external electromagnetic fields.
4.0 / 5
Reference : 17761
5,90 €tax incl.
4,92 € tax excl.
ATAUDIO Q8RF
RCA Female connector Ø7.5mm (Pair)
ATAUDIO Q8RF Connecteur RCA Femelle Ø7.5mm (La paire)
These gold-plated RCA connectors are designed to ensure good conductivity and resist oxidation. The contacts are made of high purity copper ensuring a very good transmission of the sound signal. Moreover, their body allows an effective protection against external electromagnetic fields.
xxx
Product typeRCA femelle connector
Conductive materialHigh purity copper
Contact platingGold
Max cable diameterØ7.5mm
Type of mountingTo solder
Dimensions38.5*12*8.5mm
PackageThe pair
Max cable diameter (mm)7.5
Mounting typeTo weld
ConnecticFemale
Good quality, Easy soldering
made from metal, solid feel, screw thread works smooth and locks firmly. All in all high quality appearance. Easy to solder, soldering points for + and - are on same level and avoids uneven cable lengh cutting to keep them nicely parallel.
Diameter for cable outlet (7.5mm) is only ideal for strong cable diameters - for usual audio lines too spacey (hence 4 out of 5 stars). Make sure you use large diameter audio cable for perfect fit.
This review has been posted for ATAUDIO Q8RF Female RCA Connector Ø7.5mm (The pair)
These gold-plated RCA connectors are designed to provide good conductivity and resist oxidation. The conductors are made of high purity copper for...
