CC RCA7 RCA Connectors Rhodium Plated Ø8mm Silver (Pair)
These simple yet elegant and efficient RCA connectors will allow you to design your own RCA cables. These include a brass conductor (copper alloy) with Rhodium plating, the latter providing the conductor with very good oxidation resistance for greater durability.
Reference : 12779
11,90 €tax incl.
9,92 € tax excl.
CC RCA7
Rhodium Plated RCA Connectors Silver ⌀8mm (Pair)
Connecteurs RCA
These simple yet elegant and efficient RCA connectors will allow you to design your own RCA cables. These include a brass conductor (copper alloy) with Rhodium plating, the latter providing the conductor with very good oxidation resistance for greater durability. The connector can accommodate cables up to 8mm in diameter.
Conductor materialBrass
PlatingRhodium
Housing materialAluminium alloy
Acceptable cable diameter8mm
Connection typeTo solder
Total length56.7mm
Overall diamter13.5mm
ColorSilver
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticMale
These simple yet elegant and efficient RCA connectors will allow you to design your own RCA cables. These include a brass conductor (copper alloy)...
