EIZZ EZ-202 RCA Connectors Rhodium Plated Ø7mm (Pair)
Eizz EZ-202 RCA connectors allow the conception of high quality modulation cables. They use contacts with rhodium plating to ensure maximum conductivity and durability.
Reference : 17510
31,90 €tax incl.
26,58 € tax excl.
Shipping date: 24-04-2025.
Eizz EZ-202
Eizz EZ-202 Connecteurs RCA Cuivre Tellurium plaqué Rhodium Ø8mm Noir (La paire)
Eizz EZ-202 RCA connectors allow the conception of high quality modulation cables. They use contacts with rhodium plating to ensure maximum conductivity and durability. These connectors accept cables up to 7mm in diameter.
Product typeRCA connectors
Contacts materialCopper alloy
Contacts platingRhodium
Max cable diameterØ7mm
InsulationPTFE
Mounting typeTo solder
Total dimensionsØ13*44.8mm
ColorGray
QuantityPair (1* connector with red marking, 1* connector with black marking)
Max cable diameter (mm)7.0
Mounting typeTo weld
ConnecticMale
Eizz EZ-202 RCA connectors allow the conception of high quality modulation cables. They use contacts with rhodium plating to ensure maximum...
