ELECAUDIO RC-1450 RCA Connectors Gold Plated Ø14.5mm (Pair)
These oversized ELECAUDIO RC-1450 RCA connectors accept cables up to 14.5cm in diameter, enabling you to use very large conductor cross-sections, and ensure excellent clamping quality thanks to their locking system. The connectors are gold-plated for optimum signal transmission and resistance to oxidation and corrosion.
Reference : 6838
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 23-04-2025.
ELECAUDIO RC-1450
RCA Connectors gold plated Ø14.5mm (Pair)
ELECAUDIO RC-1450 Connecteur RCA Plaqué Or Ø14.5mm (La paire)
A double cable retention system is present on this connector to prevent any pull-out (screw + ring).
Technical caracteristics
Product typeMale RCA connectors
PlatingGold
Mounting typeTo weld
Insulation PTFE
Max. cable diameter14.5mm
Connectors diameter19mm
Connectors total body lenght62mm
ColorSilver / Gold
PackageSold by pair
ELECAUDIO RC-1450 Connecteur RCA Plaqué Or Ø14.5mm (La paire) ELECAUDIO RC-1450 Connecteur RCA Plaqué Or Ø14.5mm (La paire)
Max cable diameter (mm)14.5
ConnecticMale
Connecteur RCA
Connecteur de belle qualité mais malheureusement le diamètre côté câble trop important et impossible à connecter sur bornes préampli.
This review has been posted for ELECAUDIO RC-1450 RCA Connectors Gold Plated Ø14.5mm (Pair)
These oversized ELECAUDIO RC-1450 RCA connectors accept cables up to 14.5cm in diameter, enabling you to use very large conductor cross-sections,...
