ELECAUDIO TE-RC90S RCA Plugs Tellurium Copper Silver Plated Ø8.5mm (Pair)
These RCA connectors have been designed to deliver unmatched conductivity.
4.4 / 5
Reference : 10555
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 22-04-2025.
For comparison the majority of contacts connectors in the market are based on the brass or bronze having a conductivity index (IACS) 56% against the 98/99% for Tellurium Copper.
Specifications:
  • Conductor: Tellurium Copper (IACS 98% Conductivity indice )
  • PTFE Insulation
  • Aluminium with Black anodic treatment
  • Welding
  • Accept cables up to 8.5 diameter maximum
  • Total length: 44mm
  • Diameter: 13mm
  • Weight: 12g/piece
  • Sold by pair
Max cable diameter (mm)8.5
Mounting typeTo weld
ConnecticMale
Contacts Material (Connector)Tellurium Copper
5 reviews
Difficult solder
Difficult solder coax cable ground to that wide tiny hole. Plug is not attractive to magnet and that is very good.
This review has been posted for ELECAUDIO TE-RC90S RCA Plugs Tellurium Copper Silver Plated Ø8.5mm (Pair)
Remarkable sound for a very reasonable price
The plug has all the attributes that i'm looking for, the most important being the PTFE insulation and the direct silver plating. The surprise came when i compared it with the VIBORG VR106G which has solid silver contacts and costs four times the price of the Elecaudio. To my detailed system (costing 15.000€ that are spent very carefuly) their sound is indistiguisable. This is an exceptionaly good sounding RCA plug, which is allso very well made and, to my knowledge, with the highest value/money ratio.
Très bien
Monté avec un Neotech NEI-3003 mkIII pour du coaxial, l'ensemble rend super bien et le montage passe tout juste. A moins de 50€ l'ensemble c'est du tout bon comme dirait Jacques ^^
plaquées avec votre argent !
Petite boutade pour rappeler le plaquage dont est doté le tout cuivre de ces fiches.
la coque assure une bonne robustesse à l'accessoire , la place pour effectuer la soudure du câble de modulation est suffisante ; au moment de l'opération j'oriente le câble de manière à ce que la tresse de masse soit au même niveau que le fil de point chaud et non en dessous , afin que celui-ci ne me gène pas , puis je la soude sur le côté. Question fil de soudure, préférer du fil d'étain Sn62 Pb36 Ag2 5/10 qui dès 185° assure une très belle soudure. Avec soudure sans plomb, la température de fusion étant d'une quarantaine de degrés plus élevée le plot PTFE du Pin central à tendance à se déformer. Sinon , le capuchon d' aluminium anodisé assure une bonne prise en main de la fiche qui garantit une connexion franche et robuste. Seul petit regret , la bague de couleur rouge ou blanche me semble un peu discrète.
Bon produit globalement , même si le prix me semble un peu au- dessus du raisonnable.
Superbe fiche
RQP imbattable
