ETI BRIO RCA Connectors
These RCA BRIO connectors from ETI are top-of-the-range RCA connectors designed with high-quality components. The contacts are made of rhodium-plated tellurium copper, for enhanced conductivity and resistance to corrosion and oxidation.
Reference : 18483
115,00 €tax incl.
95,83 € tax excl.
Shipping date: 24-04-2025.
RCA Connectors Copper Tellurium Rhodium Plated Ø15 x 51mm (Pair)
ETI BRIO RCA Connectors Copper Tellurium Rhodium Plated Ø15 x 51mm (Pair)
These RCA BRIO connectors from ETI are top-of-the-range RCA connectors designed with high-quality components. The contacts are made of rhodium-plated tellurium copper, for enhanced conductivity and resistance to corrosion and oxidation. The body is made of brass, providing effective protection against vibration and EMI/RFI interference. The use of these connectors ensures a final result without any alteration of the signal.
Product typeRCA connectors
COntact materialTellurium copper
COntacts platingRhodium
Body materialBrass
Mounting typeTo weld
Max. cable diameter11.5mm
Identification rings
DimensionsØ15 x 51mm
PackageSold by pair
Max cable diameter (mm)11.5
ConnecticMale
Contacts Material (Connector)Tellurium Copper
These RCA BRIO connectors from ETI are top-of-the-range RCA connectors designed with high-quality components. The contacts are...
