ETI LINK RCA Connector Tellurium Copper Ø9mm (Set x4)
Reference : 11933
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 29-09-2026.
The new ones ETI LINK RCA connectors are based on the excellent ETI Bullet, adding some improvements.
Most competitors use nickel, gilded brass or a bronze / phosphorus alloy, with a limited conductivity often below 28% International Annealed Copper Standard (IACS), and thus diminishing the performance of the components to which they connect.
On the contrary, ETI integrates in its LINK RCA connectors a pure copper signal plug with an IACS close to 102%, and a Tellurium copper return plug, and accept cables up to 9mm diameter.
The return plug, which is hollow and of very low mass, does not use hard copper which does not offer sufficient durability for welding or even for everyday use. This hollow design greatly improves the conductivity and therefore the sound quality, unlike the usual solid pins.
The shell, made of aluminum, largely limits the EMI radiation that floats around our audio systems. Thus, the body of these connectors offers a remarkable reduction in EMI / RFI noise to keep the best possible signal and offer you the most faithful resonance.
Finally, the LINK RCA incorporates two fixing screws. These allow you to effectively keep your cable out of tension when making connections.
Features :
  • Materials central pine: Copper 1100 Series IACS 102% copper
  • Body materials: Aluminum anti EMI / RF
  • Maximum rope diameter accepted: Ø 9mm
  • Sold in packs of 4
Max cable diameter (mm)9.0
Mounting typeTo weld
ConnecticMale
Contacts Material (Connector)Tellurium Copper
Top !!
Comme toujours avec Audiophonics, qualités de conseil et rapidité dans le traitement des commandes et envois. Ils sont top !!
This review has been posted for ETI LINK RCA Connector Tellurium Copper Ø9mm (Set x4)
