ETI SILVER LINK Pure Silver RCA Connector Ø11mm (Set x4)
Pure Silver RCA Connector Ø9mm (Set x4)The top-of-the-range ETI Silver Link connectors are based on the concept of the Silver Bullet, recognized by many as the best RCA connectors available today. In this new version, ETi has worked on limiting the noise induced by EMI/RFI interference. Thus, the body of the connector, made of Aluminium, makes it possible to maintain a clean signal.
By buying this product you get 28 loyalty points
Reference : 13677
289,00 €tax incl.
240,83 € tax excl.
ETI CODA RCA, the SilverLink evolution, are now available.
ETI Silver Link
ETI Silver Link Connecteur RCA Argent Pur Ø9mm (Set x4)
Pure Silver RCA Connector Ø9mm (Set x4)The top-of-the-range ETI Silver Link connectors are based on the concept of the Silver Bullet, recognized by many as the best RCA connectors available today. In this new version, ETI has worked on limiting the noise induced by EMI/RFI interference. Thus, the body of the connector, made of Aluminium, makes it possible to maintain a clean signal.
The Design
The main solution to prevent the connector from being interfered with is to get rid of the ground. The sound can be altered by the capacitance and additional resistance in the case of a too large mass. Based on this observation, ETI has chosen to greatly limit the mass. For this purpose, the silver is machined in such a way that only the signal contact is left. This method is much more expensive to manufacture but the sound result is very much present. The return contact is assembled by hand and integrated into the connector body. This ensures that the Silver Link connector can operate for years, regardless of the operating conditions and the force applied at the time of connection.
The Silver
The Silver selected by ETI for its Silver Link is largely what differentiates it from other brands' Silver connectors. Indeed, it is pure silver, and not a simple tackle. This Silver comes from a foundry in England and is worked specifically to be adapted to ETI machines. To ensure the quality of the silver used, ETI has prepared an analysis report announcing a purity of 99.99%.
Product typeRCA Connectors
Contacts materialSilver
Silver purity99.99%
Maximum cable diameterØ11mm
Minimum cable diameterØ5mm
Total dimensions51.4 x Ø14.9mm
Weight / connector10g
ColorSilver
QuantitySet of 4 connectors (2 white ring connectors, 2 black ring connectors)
Max cable diameter (mm)
  • 11.0
Mounting type
  • To weld
Connectic
  • Male
Contacts Material (Connector)
  • Silver
Contacts Plating (Connector)
  • None
2 reviews
excellentes performances
utilisé avec du nemoi 1210 argent a section rectangulaire ses rca donnent entière satisfaction. comparée a des klei. je n est pas entendu de différence notable.. je l est achetée car les klei n accepte pas le diamètre des neotech nemoi 1210. a acheter les yeux bandés si le diamètre de câble est plus grand que celui des klei.. si assez petit pour des klei..alors privilégier les klei moins cher et tous aussi exceptionnelle
This review has been posted for ETI SILVER LINK Pure Silver RCA Connector Ø11mm (Set x4)
Excelent
Fantastic contacts. Matches the sound quality of my silver cables
Pure Silver RCA Connector Ø9mm (Set x4)The top-of-the-range ETI Silver Link connectors are based on the concept of the Silver Bullet,...
