FURUTECH CF-102 NCF RCA Connectors Rhodium Plated OCC Copper Ø11mm (Pair)
Furutech introduces the CF-102 NCF high-end RCA connector. This is Furutech's first high-performance signal connector to feature the Nano Crystal² (NCF) formula. This material is the cumulative result of more than 30 years of Furutech's efforts to eliminate electrical and mechanical resonance from signal and power transmission in audio and video applications.
By buying this product you get 57 loyalty points
Reference : 15648
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 06-05-2025.
Furutech CF-102 NCF
Furutech CF-102 NCF Connecteurs RCA Cuivre OCC Plaqué Rhodium Ø11mm (La paire)
OCC Copper NCF Central conductor
The center conductor of the connector is made of Alpha (α) treated OCC copper, Rhodium plated and injected with Furutech's NCF (Nano Crystal² Formula) material, which has two active properties. First, it generates negative ions that eliminate static electricity. Second, it converts thermal energy into far infrared. Furutech combines this material with ceramic particles and carbon powder for their piezoelectric damping properties. The resulting NCF formula is the ultimate electrical and mechanical damping material.
Cryogenic process
Using state-of-the-art technology and materials, Furutech has developed a two-step, ultra-low temperature process that significantly improves every facet of transmission performance. The treatment begins during the manufacturing process with deep cryogenic freezing of all metal parts. Using efficient refrigerants, Furutech reaches temperatures between -196 and -250°C. At these temperatures, the treated parts change their molecular structure, thus relieving internal stresses. This improves electrical conductivity and thus power and signal transfer.
The second step of the Alpha process exposes these same parts to the brand's patented demagnetization treatment. The high-powered magnets used for this purpose often increase the magnetic effects, leaving some areas more magnetized than others. This patented process uses controlled attenuation to eliminate the magnetization. Thus, demagnetization further improves the conductivity of the treated materials.
Product typeMale RCA connectors
Conductor materialOCC Copper
NCF
Conductors platingRhodium
Conductors treatmentAlpha
Body materialStainless steel
Silver plated stainless steel
Carbon fiber
Max cable diameterØ11mm
Mounting typeTo screw
Total dimensionsØ14mm x 54mm
Weight29.5g
QuantitySold by 2 units
Max cable diameter (mm)
  • 11.0
Mounting type
  • To screw
Connectic
  • Male
Contacts Material (Connector)
  • Copper
Contacts Plating (Connector)
  • Rhodium
De très beau connecteurs.
Ces Superbes fiches , sont de très belle facture, très bien construites (comme toujours chez Furutech, mais là on est un cran au dessus), montage facile, avec serrage de très bonne qualité par vis (clefs fournies).
chez moi elles sont montées en hybride, RCA/XLR sur un câble symétrique FURUTECH FA-αS22 Câble de Modulation PC-OCC .Ces prises ont étendu les extrêmes, avec beaucoup de finesse, et un accroissement de la définition, par rapport aux OYAIDE FOCUS 1 Connecteurs XLR , quelles sont venues remplacées, d'un coté seulement.
This review has been posted for FURUTECH CF-102 NCF RCA Connectors Rhodium Plated OCC Copper Ø11mm (Pair)
Furutech introduces the CF-102 NCF high-end RCA connector. This is Furutech's first high-performance signal connector to feature the Nano...
