FURUTECH FP-106 (R) Rhodium Plated RCA Connectors Ø9.2mm (Set x4)
By buying this product you get 57 loyalty points
Reference : 2115
199,00 €tax incl.
165,83 € tax excl.
The Furutech FP-106 connectors, thanks to their unique clamping mode, and their very precise finish are part of the best RCA.
Features:
  • A central point made up of several Rhodium filaments treated with the "Furutech Alpha α" anti-magnetism method allowing a better contact
  • Connector lockable by rotation of the body
  • Brass body
  • Teflon insulation
  • Screw Connector
  • Maximum Body Diameter: 13.8mm
  • Total body length: 45mm
  • Maximum Acceptable Diameter (of cable): 9.2mm
  • Sold by 4
legend
https://www.audiophonics.fr/images2/6155/RCA_DIMENSIONS.jpg
Max cable diameter (mm)9.2
Mounting typeTo screw
ConnecticMale
ultimative stecker !
diese stecker sind der absolute hammer. ich hab sie an den phono cable montiert. nach 2 stunden einspielzeit offenbart sich
den progress. die musik stahlt nun aus den boxen wie nie zuvor.
es ist das geld absolut wert !
This review has been posted for FURUTECH FP-106 (R) Rhodium Plated RCA Connectors Ø9.2mm (Set x4)
