j'ai placé ces fiches sur un câble duelund en remplacement de fiche RCA duelund gold qui sont déja de très bonne qualité et je suis assez impressionné par le gain obtenu. Meme si le prix peut parait assez élevé, il est totalement justifié
This product has been replaced by the new version, the KLEI PURE22 HARMONY RCA Connectors.
Pure Silver RCA Connectors KL Formula Ø9.5mm (Set x4)
KLEI Absolute Harmony RCA connectors are designed with nothing left to chance to provide maximum conductivity. To do this, the brand uses pure silver contacts with KL Formula treatment, a patented metallurgical process that increases conductivity up to an IACS by more than 107%. This processing is controlled by mathematical modelling to optimise the relationship between mass and signal. This construction allows an excellent signal transmission.
Product type | Male RCA connectors |
Contacts material | Pure Silver, KL Formula treatment |
Max cable diameter | Ø9.5mm Ø3.5mm reducer supplied |
Mounting type | To solder + 2 holding screws |
Body material | Polymer |
Color | Black |
Quantity | Set of 4 connectors (2 with red rings, 2 with blue rings) |
Max cable diameter (mm) | 9.5 |
Mounting type | To weld |
Connectic | Male |
Contacts Material (Connector) | Silver |
Contacts Plating (Connector) | None |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
benoit s.
