KLEI ABSOLUTE HARMONY Pure Silver RCA Connectors KL Formula Ø9.5mm (Set x4)
KLEI Absolute Harmony RCA connectors are designed with nothing left to chance to provide maximum conductivity. To do this, the brand uses pure silver contacts with KL Formula treatment, a patented metallurgical process that increases conductivity up to an IACS by more than 107%.
Reference : 14186
139,00 €tax incl.
115,83 € tax excl.
This product has been replaced by the new version, the KLEI PURE22 HARMONY RCA Connectors.
KLEI Absolute Harmony Connecteur RCA Argent Pur KL Formula Ø9.5mm (Set x4)
KLEI Absolute Harmony RCA connectors are designed with nothing left to chance to provide maximum conductivity. To do this, the brand uses pure silver contacts with KL Formula treatment, a patented metallurgical process that increases conductivity up to an IACS by more than 107%. This processing is controlled by mathematical modelling to optimise the relationship between mass and signal. This construction allows an excellent signal transmission.
Product typeMale RCA connectors
Contacts materialPure Silver, KL Formula treatment
Max cable diameterØ9.5mm
Ø3.5mm reducer supplied
Mounting typeTo solder + 2 holding screws
Body materialPolymer
QuantitySet of 4 connectors (2 with red rings, 2 with blue rings)
Max cable diameter (mm)
  • 9.5
Mounting type
  • To weld
Connectic
  • Male
Contacts Material (Connector)
  • Silver
Contacts Plating (Connector)
  • None
une amélioration étonnante
j'ai placé ces fiches sur un câble duelund en remplacement de fiche RCA duelund gold qui sont déja de très bonne qualité et je suis assez impressionné par le gain obtenu. Meme si le prix peut parait assez élevé, il est totalement justifié
This review has been posted for KLEI ABSOLUTE HARMONY Pure Silver RCA Connectors KL Formula Ø9.5mm (Set x4)
KLEI Absolute Harmony RCA connectors are designed with nothing left to chance to provide maximum conductivity. To do this, the brand uses pure...
