KLEI PURE22 HARMONY Male RCA Connectors Silver Plated Copper Ø9.5mm (Set x4)
These KLEI Pure22 Harmony RCA connectors represent the most advanced model of the brand. A proprietary mathematical model is used to define the relationship between the ground and the signal pin of the Perfect Harmony and thus determine the appropriate metallurgical processes. This method allows to reach an excellent conductivity, higher than 101% IACS, even 105% IACS.
Reference : 16488
189,00 €tax incl.
157,50 € tax excl.
Shipping date: 22-04-2025.
KLEI pure22 Harmony
KLEI Perfect22 Harmony Connecteurs RCA Mâles Cuivre Plaqué Argent Ø9.5mm (Set x4)
These KLEI Pure22 Harmony RCA connectors represent the most advanced model of the brand. A proprietary mathematical model is used to define the relationship between the ground and the signal pin of the Perfect Harmony and thus determine the appropriate metallurgical processes. This method allows to reach an excellent conductivity, higher than 101% IACS, even 105% IACS. These connectors are also perfectly suited for the creation of digital SPDIF cables. They can also withstand the high temperature required for silver soldering. A two screw system allows a perfect hold of the cable in the connector.
Product typeMale RCA connectors
Mounting typeTo solder
Compatible cable diameterFrom 4mm to 9.5mm
Contacts materialSilver plated copper
Connector body materialThermoplastic polymer with glass fiber
QuantitySold by 4 (2x connectors with red ring, 2x connectors with white ring)
Max cable diameter (mm)9.5
Mounting typeTo weld
ConnecticMale
2 reviews
Une merveille
Une merveille à souder, les soudures argent se déposent sur les pâtes à merveille. On dirait qu du flux est déjà présent c'est bluffant. Plastique TRES résistant à la chaleur du fer.
Particulièrement adapté pour un cablage en masse flottante avec un câble symétrique (alpha S22 de chez furutech).
Les deux pâtes à souder se présentant de part et d'autre au même endroit.
Sonne merveilleusement bien, il a énormément aéré mon écoute.
 (4)
This review has been posted for KLEI PURE22 HARMONY Male RCA Connectors Silver Plated Copper Ø9.5mm (Set x4)
Stratosphériques !
Tout comme d'autres ici, la réception m'a laissé quelque peu dubitatif, voyant un plastique apparemment léger. Rien à voir avec d'autres fiches en métal massif.
Une fois montées avec un câble NEOTECH NEI-3001 MKIII, quelques heures ont suffi pour m'en convaincre. Le niveau atteint par ces deux là est stratosphérique !!
Mon Van Den Hull First Ultimate qui pourtant, avait battu le NEOTECH NOMOI 3220, a explosé en vol !
En bref, il faut surmonter l'aspect un rien léger de ces connecteurs, au moins en apparence car ils cachent bien leur jeu, l'écoute elle, révèle l'étonnant potentiel musical de ces connecteurs RCA, impossible de les mettre en défaut !
En association avec le câble NEOTECH NEI-3001 MKIII, on obtient un câble de très haut vol, pour moins de 250 euros en deux fois un mètre. Je n'en suis pas encore revenu, son écoute m'a scotché.
 (4)
These KLEI Pure22 Harmony RCA connectors represent the most advanced model of the brand. A proprietary mathematical model is used to define the...
