Male RCA connectors Gold-plated Ø8.5mm (Set x4)
These RCA connectors enable the design of high-quality modulation cables, ensuring optimum transmission of the audio signal. The gold-plated pure copper contacts combine excellent conductivity with flawless protection against oxidation. The teflon insulation and brass connector body greatly limit the impact of interference on the signal. Mounting is simply by soldering, and 4 heat-shrink sleeves are supplied.
Reference : 19691
29,90 €tax incl.
24,92 € tax excl.
Male RCA connectors : Set of 4
Technical specifications
Product typeMale RCA connectors
Contacts materialPure copper
Contacts platingGold
InsulationTeflon
Body materialBrass
Mounting typeTo weld
Max cable diameterØ8.5mm
Dimensions15.5 x 43.6mm
Package4x Male RCA connectors
4x Heat-shrink sleeves
1x Allen key
Max cable diameter (mm)8.5
ConnecticMale
These RCA connectors enable the design of high-quality modulation cables, ensuring optimum transmission of the audio signal. The gold-plated pure...
