Male RCA connectors Silver-plated Ø8.5mm (Set x4)
These RCA connectors enable the design of high-quality modulation cables, ensuring optimum transmission of the audio signal. The silver-plated pure copper contacts combine excellent conductivity with flawless protection against oxidation. The teflon insulation and brass connector body greatly limit the impact of interference on the signal. Mounting is simply by soldering, and 4 heat-shrink sleeves are supplied.
4.0 / 5
Reference : 19694
35,90 €tax incl.
29,92 € tax excl.
Shipping date: 25-04-2025.
Male RCA connectors : Set of 4
Technical specifications
Product typeMale RCA connectors
Contacts materialPure copper
Contacts platingSilver
InsulationTeflon
Body materialBrass
Mounting typeTo weld
Max cable diameterØ8.5mm
Dimensions15.5 x 43.6mm
Package4x Male RCA connectors
4x Heat-shrink sleeves
1x Allen key
Max cable diameter (mm)8.5
ConnecticMale
Oui, mais
Les connecteurs sont beaux lourds respirent la qualité,mais
La connexion aux entrées RCA de l' ampli est difficile. Ils sont étroit et il fait forcer pour enficher, trop forcer. A tel point que les embases se détachent de l' ampli ( fosi za3). Dommage, je ne les recommande pas a moins d' avoir des embases de qulites
This review has been posted for Male RCA connectors Silver-plated Ø8.5mm (Set x4)
These RCA connectors enable the design of high-quality modulation cables, ensuring optimum transmission of the audio signal. The silver-plated pure...
