By buying this product you get 26 loyalty points
RCA Connectors Platine / Rhodium Plated Ø9mm (Set x4)
After a year of research and testing, Oyaide offers Genesis high-end RCA connectors. They benefit from an extremely careful design, using a copper alloy as contacts, with double platinum and rhodium plating. They provide excellent conductivity for optimal signal transmission, while resisting the ravages of time. The body of the connector is also made of the same materials, where the internal insulation is PTFE. All materials used are CNC machined, ensuring high accuracy.
The cable clamp part of the connector is independent from the rest of the connector, allowing a particularly effective hold and limiting vibrations.
Product type | RCA Connectors |
Contacts material | Copper alloy |
Contacts plating | Platine 1.5µ + Rhodium 0.3µ |
Resin insert material | PTFE |
Body material | Copper alloy (RoHS) |
Body plating | Platine 1.5µ + Rhodium 0.3µ Chrome surface treatment |
Cable clamp material | Copper alloy(RoHS) |
Mounting type | To solder |
Max cable diameter | Ø9mm |
Color | Silver |
Quantity | Sold by 4 (2 units with white ring, 2 units with red ring) |
Max cable diameter (mm) | 9.0 |
Mounting type | To weld |
Connectic | Male |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Rhodium |
