OYAIDE SLSC RCA Plug 4N Pur Silver Ø9mm (Set x4)
By buying this product you get 35 loyalty points
Reference : 11518
359,00 €tax incl.
299,17 € tax excl.
Shipping date: 15-04-2025.
These 100% Japanese made OYAIDE SLSC RCA connectors have been designed and designed to offer a very high quality and reliability standard for your audio connector.
TheThe materials chosen by the manufacturer are of high quality and the finishes are really excellent.
The connectors are the signal gateway, therefore they are the ones that define the quality of the sound. Pure silver 4N was used in all the metals of the spindle for its very high electrical conductivity properties. Finally, the contact pin of the RCA connector has been hand polished for impeccable accuracy.
The fabriquetted in Brass and treated CNC is of high density and has a high shielding performance. The chromium plating was applied very accurately.
The isolant is a truly important factor in improving signal transmission capabilities. This is why PTFE has been chosen on these RCA connectors, the latter providing excellent electrical insulation and low electrical permittivity.
Features:/ Strong>
  • 4N Pure Silver Conductors
  • CNC machining (CNC machine)
  • PTFE Insulation
  • Excellent conductivity
  • Polishing by hand: piece by piece
  • Cable diameter: Ø 9mm maximum
  • Sold in lots of 4: 2 white + 2 red
Max cable diameter (mm)9.0
Mounting typeTo weld
ConnecticMale
Contacts Material (Connector)Silver
