RCA Connector 90° Angled Gold Plated Ø6.2mm (Pair)
These gold-plated RCA connectors are ideal for your DIY installations. They can accommodate cables up to 6.2mm in diameter. The assembly of the cables is done by soldering. Gold conductors provide good conductivity and resistance to oxidation.
Reference : 17684
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 06-05-2025.
RCA Connectors
Connecteur RCA coudé 90° Plaqué Or Ø6.2mm (Unité)
These gold-plated RCA connectors are ideal for your DIY installations. They can accommodate cables up to 6.2mm in diameter. The assembly of the cables is done by soldering. Gold plated contacts provide good conductivity and resistance to oxidation.
Product typeRCA Connector
Max. cable diameterØ6.2mm
Contact plating Or
Shell materialMetal
Angled90°
MountingTo solder
Total dimensions33*29*12mm
PackageSold by 2
Max cable diameter (mm)
  • 6.2
Mounting type
  • To weld
Connectic
  • Male
Contacts Material (Connector)
  • Copper Alloy
Contacts Plating (Connector)
  • Gold
These gold-plated RCA connectors are ideal for your DIY installations. They can accommodate cables up to 6.2mm in diameter. The assembly of the...
