VIABLUE T8 SOLDER RCA Connectors
These RCA T8 Solder connectors from Viablue feature a high quality design. They feature 24k" gold-plated contacts for enhanced conductivity and resistance to corrosion and oxidation.
Reference : 18490
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 24-04-2025.
VIABLUE T8 SOLDER
Gold-plated RCA connectors Ø9.5mm (Pair)
VIABLUE T8 SOLDER Gold-plated RCA connectors Ø9.5mm (Pair)
These RCA T8 Solder connectors from Viablue feature a high quality design. They feature 24k gold-plated contacts for enhanced conductivity and resistance to corrosion and oxidation. The matte black aluminum body of these connectors also gives them a high level of durability and modern aesthetics. Mounting is by soldering, while two M4 1.5mm hexagon socket screws hold the cable and connector securely in the body. The Viablue T8 Solder connector accepts cable diameters from Ø4mm to Ø9.5mm, depending on the use of the reducer supplied.
Product typeRCA connectors
Contacts platingOr 24k"
Body materialAluminum
Min. cable diameterØ4mm
Max. cable diameterØ9.5mm
Body length30.5mm
Identification rings
Overall dimensions45 x Ø13.5mm
Weight10g/connector
PackageSold by pair
Max cable diameter (mm)9.5
Mounting typeTo weld
ConnecticMale
Très bien !!
Fiches utilisées pour monter un câble numérique blindé en argent pur monobrin Xangsane XS-1001Ag diamètre 9mm.
Très bien au niveau des soudures et des vis qui bloquent bien le câble.
Il a fallu que je frotte avec du papier de verre pour réduire le diamètre de la gaine du câble Xangsane qui est un peu trop épaisse et la rentrer avec de la vaseline, les fiches n'y sont pour rien.
Top livraison Audiophonics !!
This review has been posted for VIABLUE T8 SOLDER Gold Plated RCA Connectors Ø9.5mm (Pair)
These RCA T8 Solder connectors from Viablue feature a high quality design. They feature 24k"...
