VIABLUE TVR Connectors RCA Plated Gold Ø8mm (Pair)
4.6 / 5
Reference : 3417
14,90 €tax incl.
12,42 € tax excl.
Disconnecting the standard RCA cables often leads to breakage of the cable, resulting in defects in the contacts and therefore loss of image or sound quality.
The objective of the ViaBlue ™ TVR connectors was to produce a connector that prevents cable breakage.
Moreover with an internal shield of the socket associated with an easy and practical installation this connector requires more than necessary
Also featuring genuine plating in 24K Gold.
The result is a high-end connector that is easy to handle and install to get the best out of your image or sound.
Each TVR connector has a screw to make contact with the cable core.
However it can also be welded.
The cable inserted into the connectors is locked by a large screw that holds it firmly
Features:/ Strong>
  • Plated Gold24 Carats.
  • Prevents tearing of the cable by a good fixation
  • Maximum acceptable diameter (of cable): 8.0mm
  • 100% shield into connector
  • Easy to install
  • Maximum Body Diameter: 13 mm
  • Total body length:40 mm
https://www.audiophonics.fr/images2/3417/3417_viablue_connecteurs_thumbs.png
https://www.audiophonics.fr/images2/3417/3417_viablue_connecteurs_1.jpg
https://www.audiophonics.fr/images2/3417/3417_viablue_connecteurs_2.jpg
https://www.audiophonics.fr/images2/3417/3417_viablue_connecteurs_3.jpg
Caption:
https://www.audiophonics.fr/images2/6155/RCA_DIMENSIONS.jpg
Max cable diameter (mm)8.0
Mounting typeTo screw
ConnecticMale
5 reviews
Belle fabrication très solide; montage sans soudure possible;bon rapport qualité /prix
This review has been posted for VIABLUE TVR Connectors RCA Plated Gold Ø8mm (Pair)
Excellent rapport qualité prix
Trés bonne qualité de transmission contact et serrage sur entrée de mon ampli yam parfait.Pus de faux contact et c'est la premiére fois que je rencontre une fiche rca qui est ni trop dure à mettre ni trop lache.Enfin le serrage des conducteurs est trés bien mais prévoir quand méme un petite clé allen. Je signale que de part mon métier je préfere un serrage du conducteur ou un sertisage que de la soudure aussi bonne soit elle.
excellent produit
Dorure de qualité supérieure.Se soude très bien.Juste faire attention au passage du cable qui doit se limiter au juste 8mm, pas un chouia de plus.Sinon parfait.
Le serrage par clé alen est le meilleur qui soit en terme de puissance de contact ,les dimension des outils sont normalisées et facile à trouver .
Ces connecteurs RCA sont solides et très bien finis. Seul reproche, ce n'est pas un tournevis qu'il faut pour serrer les vis comme la photo semble le laisser supposer mais une clé 6 pans de taille lilliputienne que je n'ai pas trouvé en boutique de bricolage. J'ai du utiliser la pointe de mon couteau suisse! Si Audiophonics pouvait fournir la clé qui convient, je n’hésiterai pas à racheter ce modèle.
