VIBORG VR105G RCA Connectors
Viborg VR105G RCA connectors enable the design of high-quality modulation cables, ensuring optimum transmission of the audio signal. The pure copper contacts, triple plated with OFC copper, silver and gold, ensure maximum conductivity and protection against oxidation. Polyethylene (PE) and fibreglass insulation coupled with a non-magnetic copper alloy body provide protection against external magnetic fields that could interfere with your signal. The maximum cable diameter accepted by these connectors is 8.5mm and connection is by solder.
2.0 / 5
Reference : 19336
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 29-04-2025.
VIBORG VR105G Gold-plated OFC copper RCA connectors Ø8.5mm (Set x4)
VIBORG VR105G : Front view
Product typeMale RCA connectors
Contacts materialPure copper
Contacts platingOFC copper
Silver
24k Gold
InsulationPolyethylene (PE)
Glass fibre
Body materialEngraved copper alloy
Mounting typeSoldering
Max cable diameterØ8.5mm
ColorGrey with red ring
Grey with blue ring
Package2x VIBORG VR105G with red ring
2x VIBORG VR105G with blue ring
Max cable diameter (mm)8.5
Mounting typeTo weld
ConnecticMale
attention corps en plastique
a réserver au pro de la soudure. (il faut etre sur et rapide )le corps en plastique ne pardonne pas si vous le toucher avec votre fer. Ou si vous passer trop de temp sur la soudure.
attention la vis de serrage est très petite, vite perdu!!
This review has been posted for VIBORG VR105G RCA Connectors Gold Plated OFC Copper Ø8.5mm (Set x4)
Viborg VR105G RCA connectors enable the design of high-quality modulation cables, ensuring optimum transmission of the audio signal. The pure...
