VIBORG VR105S RCA connectors
Viborg VR105S RCA connectors enable the construction of high-quality modulation cables, ensuring optimum transmission of the audio signal. The pure copper contacts with double OFC copper/silver plating ensure maximum conductivity combined with flawless protection against oxidation. Polyethylene (PE) and fibreglass insulation coupled with a non-magnetic copper alloy body provide protection against external magnetic fields that could interfere with your signal. The maximum cable diameter accepted by these connectors is 8.5mm and connection is by solder.
Reference : 19333
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 25-04-2025.
VIBORG VR105S Silver-plated OFC copper RCA connectors Ø8.5mm (Set x4)
VIBORG VR105S : Front view
Product typeMale RCA connectors
Contacts materialPure copper
Contacts platingOFC copper
Silver
InsulationPolyethylene (PE)
Glass fibre
Body materialEngraved copper alloy
Mounting typeSoldering
Max cable diameterØ8.5mm
ColorGrey with red ring
Grey with blue ring
Package2x VIBORG VR105S with red ring
2x VIBORG VR105S with blue ring
Max cable diameter (mm)8.5
Mounting typeTo weld
ConnecticMale
VIBORG VR105S RCA Connectors Silver Plated OFC Copper Ø8.5mm (Set x4)
Viborg VR105S RCA connectors enable the construction of high-quality modulation cables, ensuring optimum transmission of the audio signal. The pure...
