VIBORG VR108 RCA Connectors Copper Ø10mm (Set x4)
The Viborg VR108 RCA connectors allow for the design of high quality modulation cables, ensuring optimal audio signal transmission. They use copper contacts, offering excellent electrical conductivity and PTFE insulation, limiting the impact of interference on the signal. The body is made of stainless steel and carbon fiber. Mounting is simple using a screw system.
Reference : 16620
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 22-04-2025.
Viborg VR108
Viborg VR108 Connecteurs RCA Cuivre Ø10mm (Set x4)
Product typeMale RCA connectors
Contacts materialPure copper
InsulationPTFE
Body materialStainless steel
Carbon fiber
Mounting typeTo screw
Max cable diameterØ10mm
DimensionsØ19.2 x 56.3mm
Max cable diameter (mm)10.0
ConnecticMale
The Viborg VR108 RCA connectors allow for the design of high quality modulation cables, ensuring optimal audio signal transmission. They use copper...
