VIBORG VR108R RCA Connectors Silver / Rhodium Plated OFC Copper Ø10mm (Set x4)
The Viborg VR108G RCA connectors allow for the design of high quality modulation cables, ensuring optimal audio signal transmission. They use copper contacts with triple OFC copper, silver and 24k gold plating, offering excellent electrical conductivity, and benefit from PTFE insulation, limiting the impact of interference on the signal. The body is made of stainless steel and carbon fiber. Mounting is simple with a screw system.
Reference : 16622
175,00 €tax incl.
145,83 € tax excl.
Shipping date: 25-04-2025.
Viborg VR108R
Viborg VR108R Connecteurs RCA Cuivre Plaqué Argent / Rhodium Ø10mm (Set x4)
The Viborg VR108R RCA connectors allow for the design of high quality modulation cables, ensuring optimal audio signal transmission. They use copper contacts with triple OFC copper, silver and rhodium plating, offering excellent electrical conductivity, and benefit from PTFE insulation, limiting the impact of interference on the signal. The body is made of stainless steel and carbon fiber. Mounting is simple with a screw system.
Product typeMale RCA connectors
Contacts materialPure copper
Contacts platingOFC Copper
Silver
Rhodium
InsulationPTFE
Body materialStainless steel
Carbon fiber
Mounting typeTo screw
Max cable diameterØ10mm
DimensionsØ19.2 x 56.3mm
Max cable diameter (mm)10.0
ConnecticMale
The Viborg VR108G RCA connectors allow for the design of high quality modulation cables, ensuring optimal audio signal transmission. They use...
