VIBORG VR109 RCA Connector Pure copper PTFE Ø9.5mm (Set x4)
Reference : 13312
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 02-04-2025.
VIBORG VR109
VR109 RCA connectors Viborg with pure copper conductor. Ideal material to enjoy a superior conductivity and preserve your audio signal in all its clarity.
The outer shell is constructed from an aluminum and alloys in order to take advantage of a light structure, strong and durable. The VR109 can be connected to mass wirings without placing an excessive pressure to the female connector.
Connector's isolation is made of PTFE which is an efficient protection against thermal stresses, corrosion, humidity. This allows the connector to keep its electrical properties for a long time.
TypeRCA connector
KindMale
DriverPure copper
ShellAluminum alloy
InsulationPTFE (white)
max cable diameter9.5mm
Dimensions13.9φ x 14.4mm x 51.5 mm
ConnectionSolder
Package Contents
Red ring connectorx2
Black ring connectorx2
Max cable diameter (mm)9.5
Mounting typeTo weld
ConnecticMale
