VIBORG VR109R RCA Connector Pure Copper Silver / Rhodium plated PTFE Ø9.5mm (Set x4)
Reference : 13313
95,00 €tax incl.
79,17 € tax excl.
Shipping date: 25-04-2025.
VIBORG VR109R
VR109G
VR109 RCA connectors Viborg with Silver / Rhodium plated pure copper conductor. This model benefits from copper great conductivity which is a long-lasting feature thanks to Rhodium capacity of protecting conductors without affecting electric signal.
The outer shell is constructed from an aluminum and alloys in order to take advantage of a light structure, strong and durable. The VR109 can be connected to mass wirings without placing an excessive pressure to the female connector.
Connector's isolation is made of PTFE which is an efficient protection against thermal stresses, corrosion, humidity. This allows the connector to keep its electrical properties for a long time.
TypeRCA connector
KindMale
DriverPure copper
PlatingSilver / Rhodium
ShellAluminum alloy
InsulationPTFE (white)
max cable diameter9.5mm
Dimensions13.9φ x 14.4mm x 51.5 mm
ConnectionSolder
Package Contents
Red ring connectorx2
Black ring connectorx2
Max cable diameter (mm)9.5
Mounting typeTo weld
ConnecticMale
