WBT-0152 Ag Nextgen RCA Plug Pure Silver Ø10.8mm (Set x4)
4.5 / 5
By buying this product you get 33 loyalty points
Reference : 7905
339,00 €tax incl.
282,50 € tax excl.
WBT-0152 Ag Nextgen RCA Plug Silver Plated Ø 10.8mm (Set x4)
Among the last two models released, the WBT 0152 is based on the Nextgen technology principle. It differs from model 0102 by the cable section it accepts (10.8mm).
The essential element influencing the sound quality is the central contact which has been developed in exactly the same way as on the WBT0110 model: Minimum conductor mass made of fine silver.
Silver was chosen for its qualities of electrical conductivity, its speed and the fineness of the information it lets through. The silver elements are treated in such a way that they are not subject to any corrosion or migration that is harmful to the quality of the contact.
The particularity of this model lies in its bandwidth which goes up to 200 MHz, well beyond the usual standard for RCA plugs.
The upper part of the plug is easily and securely clipped to the RCA plug body by means of a locking system, thus ensuring maximum contact as well as safety of the connection.
The external tightening cone of the RCA plug adapts to the diameter defects of the RCA socket. Our closing system guarantees a safe and firm contact without any risk of twisting the cable during tightening.
The central pin is equipped with mechanical springs allowing perfect electrical contact under all conditions and minimum contact resistance.
The body is made of brass plated to the Platinum in order to accept large and rigid cables. The metal body is, of course, decoupled from the central core and contains a very small amount of metal in order to be insulated from Eddy currents.
Télécharger la documentation
Features:
  • Pure Silver conductor
  • Soldering
  • Rope diameter: 10.8 mm maximum
  • Sold by 4
https://www.audiophonics.fr/images2/7904/7905_wbt_0152_cnnector_rca_1.jpg
Max cable diameter (mm)10.5
Mounting typeTo weld
ConnecticMale
Contacts Material (Connector)Silver
2 reviews
Super Stecker spielt sehr neutral
Die Silver Steckern spielen sehr neutral detailreich flüssig sehr sauber musikalisch und der Bass kompakt trocken und sehr schnell.
Vorsicht!!
Im Vergleich zu Standardsteckern spielen die WBT viel zurückhaltend
und Neutral daher sind sie für Musikanlagen die zu dynamisch unsauber und zu offen spielen geeignet.
Alle neue WBT CU bzw AG Steckern spielen wie oben beschrieben ist
wer mehr Bass sehr offen bevorzugt , sollte was anderes kaufen Massivsteckern spielen mit mehr Druck im Bass und Dynamischer.
This review has been posted for WBT-0152 Ag Nextgen RCA Plug Pure Silver Ø10.8mm (Set x4)
Excellent
Admittedly, I bought elsewhere on a special offer. As other reviews have said, removing the central body to solder snaps the holding pins, until I realised you dont need to remove it to solder properly. Still, its an expensive plug to break so easily.
Sound? They give an instant additional sparkle to my Neotech 1120 cable and extra depth perception. There is only 50 hours burn in on them so still opening up. A worthwhile investment if you have the cables to warrant the investment.
