XANGSANE XS-6001AU RCA Connectors
These XS-6001AU RCA connectors from Xangsane are top-quality connectors. The contacts are made of copper alloy and silver-plated, for optimal conductivity.
Reference : 18809
20,90 €tax incl.
17,42 € tax excl.
Shipping date: 22-04-2025.
XANGSANE XS-6001AU RCA Connectors 24k Silver Ø8.5mm (Set x4)
XANGSANE XS-6001AU Connecteurs RCA Plaqué Argent Ø8.5mm (Set x4)
These XS-6001AU RCA connectors from Xangsane are top-quality connectors. The contacts are made of copper alloy and silver-plated, for optimal conductivity. The insulation is made of nylon for its flame-retardant properties and resistance to high temperatures. The outer shell is made of copper for durability. These XS-6001AU RCA connectors from Xangsane are solderable and accept cable diameters up to Ø8.5mm. Two screws on the side of the connector ensure that the cable is securely attached to the RCA connector.
XANGSANE XS-6001AU RCA Connectors Silver Plated Ø8.5mm (Set x4)
Product typeMale RCA connectors
Contact materialCopper alloy
Contact platingSilver
Body materialCopper
Insulation materialNylon
Max. cable diameterØ8.5mm
DimensionsØ14 x 51mm
Weight25g / connector
ColorBlue
PackageXangsane XS-6001AU RCA connector (Set x4)
Max cable diameter (mm)8.5
Mounting typeTo weld
ConnecticMale
2 reviews
C’est avec beaucoup de regret que j’ai monté les prises sur les câbles (SOMMERCABLE TRICONE XXL) car ils sont très beaux.
Construction simple et soudure facile.
Excellent produit.
This review has been posted for XANGSANE XS-6001AU RCA Connectors Silver Plated Ø8.5mm (Set x4)
Superbe Fiche RCA
Très bonne fiches RCA, meilleur que les viborg VR105S en comparaison. Meilleures Sonorité,plus dynamique, et une meilleur ouverture sonore. Simple à souder. Fiche très haut de gamme pour un prix très modérer.
 (3)
These XS-6001AU RCA connectors from Xangsane are top-quality connectors. The contacts are made of copper alloy...
