XANGSANE XS-R13 RCA Connectors 24k Gold Plated Ø7mm (Set x4)
These XS-R13 RCA connectors from Xangsane are high quality connectors. The contacts are made of copper alloy and are 24k gold-plated, for enhanced conductivity and optimum resistance to corrosion and oxidation. They also incorporate nylon insulation.
Reference : 18097
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 03-04-2025.
XANGSANE XS-R13
These XS-R13 RCA connectors from Xangsane are top-quality connectors. The contacts are made of copper alloy and are 24k gold-plated, for better conductivity and optimum resistance to corrosion and oxidation. The insulation is made of nylon for its flame-retardant properties and resistance to high temperatures. The outer shell is made of aluminum for durability and protection against interference. These XS-R13 RCA connectors from Xangsane are weld-type and accept cable diameters up to Ø7mm. Two screws on the side of the connector ensure secure attachment of the cable to the RCA connector.
Product typeMale RCA connectors
Contacts materialCopper alloy
Contact splatingGold 24k
Body materialAluminum
Insulation materialNylon
Max. cable diameterØ7mm
DimensionsØ14*49mm
Weight20g / connector
Package4* Xangsane XS-R13 RCA connectors
Max cable diameter (mm)7.0
Mounting typeTo weld
ConnecticMale
2 reviews
My Favorite!
RCA plug with a great price-quality ratio. Stable, easy to solder and well thought out. Best soldered plugged in. My recommendation and my favorite!
This review has been posted for XANGSANE XS-R13 RCA Connectors 24k Gold Plated Ø7mm (Set x4)
4 connecteurs rca.
Très bonne qualité.
Résiste bien à la chaleur et facile à souder. Le contact est bon et pas trop difficile comme d'autres marques.
Pour 20e les 4 le rapport qualité prix est excellent.
These XS-R13 RCA connectors from Xangsane are high quality connectors. The contacts are made of copper alloy and are 24k gold-plated, for enhanced...
