XANGSANE XS-T1061 RCA Connectors 24k Gold Plated Ø9mm (Set x4)
These XS-T1061 RCA connectors from Xangsane feature a quality design using top-of-the-range materials. The contacts are made of 24k gold-plated copper alloy. This gives them high conductivity and resistance to corrosion and oxidation.
4.8 / 5
Reference : 18099
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 27-12-2024.
XANGSANE XS-T1061
XANGSANE XS-T1061 Connecteurs RCA Plaqué Or 24k Ø9mm (Set x4)
These XS-T1061 RCA connectors from Xangsane feature a quality design using top-of-the-range materials. The contacts are made of 24k gold-plated copper alloy. This gives them high conductivity and resistance to corrosion and oxidation. The body of these connectors is also made of copper, making them tough and durable. The structure of these RCA connectors allows them to be completely disassembled for easy screw mounting. Moreover, their design makes them self-locking, so all you need to do to tighten these RCA connectors is turn their body counter-clockwise. They accept cables up to Ø9mm in diameter and are sold per 4.
Product typeRCA Connectors
Contacts materialCopper alloy
Contacts plating24k gold
Body materialCopper
Max. cable diameterØ9mm
Mounting typeTo screw
Self-locking
Total dimensions55*Ø14mm
Weight26g
PackageSet x4
Max cable diameter (mm)9.0
ConnecticMale
9 reviews
TRES BON CONNECTEURS
Monté avec du câble CANARE L-4E6S STAR QUAD,rajout de scotch autour de la gaine pour compenser le diamètre du câble et pouvoir le fixé dans le connecteur,très bonne qualité,reçu rapidement.Merci audiophonics
This review has been posted for XANGSANE XS-T1061 RCA Connectors 24k Gold Plated Ø9mm (Set x4)
Incroyable rapport Q/P
Très belle surprise à la réception de ces fiches, excellente qualité de fabrication et finition. Le serrage à vis du point central est très efficace et offre un contact parfait, la masse se fait très bien en enroulant le fil dénudé autour de la gaine du câble au niveau du serre câble arrière ainsi le contact se fait avec le corps de la fiche. Le serrage sur les embases est très efficace. Bref, un produit au rapport qualité/prix incroyable.
Sans Soudure ?
Je ne vois pas comment ne pas souder la tresse de blindage. Il n'y a qu'une vis pour le point chaud et une pour le serre câble. J' ai essayé via le serre câble mais se n' est pas fiable. Je n'ai sûrement pas compris cette fiche !
Bonne surprise
Ces connecteurs sont de très belle facture et s'adaptent parfaitement un câble de 9mm, il s'en dégage une impression de qualité. Le point chaud est maintenu par une vis BTR que l'on peut serrer fermement sans l'endommager. Une astuce pour souder la masse sur le corps du connecteur, j'ai mis un coup de pince coupante au milieu de la bague de soudage, j'en ai enlevé une moitié avec un pince. Il reste un demi anneau au bout duquel il est très facile de faire un point de soudure. On peut légèrement enfoncer la partie restante pour que la soudure ne viennent pas gêner le vissage du corps. J'ai utilisé de la soudure Dynavox, vendue sur le site, elle est parfaite pour ce travail. A l'écoute, s'il y a une différence avec mes anciens connecteurs beaucoup plus chers.....c'est très à la marge. Merci à l'équipe toujours à l'écoute, des pros!
Très bons connecteurs
Connecteurs parfaits avec l'avantage de ne pas avoir de soudure à faire . Ils sont très bien réalisés et robustes , avec un joli aspect , je recommande vivement .
These XS-T1061 RCA connectors from Xangsane feature a quality design using top-of-the-range materials. The...
