YARBO RCA-019GB Gold 24k Plated RCA Connectors PTFE Ø7mm (Pair)
The RCA Yarbo RCA-019GB connectors are models that benefit from a high quality manufacturing process. In a robust metal body are integrated 24k gold plated contacts, ensuring very good audio signal conductivity and oxidation resistance for greater durability.
Reference : 13721
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 22-04-2025.
Yarbo RCA-019GB
Yarbo RCA-19GB Connecteurs RCA Plaqué Or 24k PTFE Ø7mm (La paire)
The RCA Yarbo RCA-019GB connectors are models that benefit from a high quality manufacturing process. In a robust metal body are integrated 24k gold plated contacts, ensuring very good audio signal conductivity and oxidation resistance for greater durability. The connector has PTFE isolation to reduce interference that could affect the signal and therefore the audio output. RCA-019GB can accept cables up to 7mm in diameter.
Yarbo RCA-019GB Connecteurs RCA Plaqués Or 24k PTFE Ø7mm (La Paire)
Product typeRCA Connectors
Conductors platingGold 24k
Max cable diameter7mm
Connection typeTo solder
InsulationPTFE
Totals dimensions54.1 x 14.2mm
QuantitySold per pair (1x red marked connector, 1x white marked connector)
Max cable diameter (mm)7.0
Mounting typeTo weld
ConnecticMale
Très bonne fiches
Ces fiches sont parfaites. Montées sur un coax sommercable, le montage est très facile. La soudure du point chaud est facilite par la taille de la base du pin central . A cela s'ajoute le vissage de la masse... en tout 5 minutes de montage.
Rapport qualité/ prix top +++.
This review has been posted for YARBO RCA-019GB Gold 24k Plated RCA Connectors PTFE Ø7mm (Pair)
The RCA Yarbo RCA-019GB connectors are models that benefit from a high quality manufacturing process. In a robust metal body are integrated 24k...
