Pure Silver RCA Connector Ø9mm (Set x4)
The top-of-the-range ETI Link RCA connectors are based on the Silver Bullet concept, recognized by many as the best RCA connectors available today. In this new version, ETI has worked on limiting the noise induced by EMI/RFI interference.
The main solution to prevent the connector from being interfered with is to get rid of the ground. The sound can be altered by the capacitance and additional resistance in the case of a too large mass. Based on this observation, ETI has chosen to greatly limit the mass. For this purpose, the silver is machined in such a way that almost only the signal contact is left. This method is much more expensive to manufacture but the sound result is very much present.
The Silver selected by ETI for its Silver Link is largely what differentiates it from other brands' Silver connectors. Indeed, it is pure silver, and not a simple tackle. This Silver comes from a foundry in England and is worked specifically to be adapted to ETI machines. To ensure the quality of the silver used, ETI has prepared an analysis report announcing a purity of 99.99%.
Product type | RCA Connector |
Contacts material | Silver |
Silver purity | 99.99% |
Max cable diameter | Ø9mm |
Min cable diameter | Ø2.8mm |
Total dimensions | 47.9 x Ø13.5mm |
Color | Black |
Quantity | Set of 4 connectors (2 white marked connectors, 2 black marked connectors) |
