Gold Plated RCA Connectors Ø9.5mm (Pair)
These Viablue T6S RCA connectors benefit from an impeccable manufacturing quality. With their 24-carat gold-plated contacts, they offer very good audio signal conductivity while providing excellent oxidation resistance for greater durability. The connector body is made of matt black aluminium with the most beautiful effect. M4 1.5mm hexagon socket screws allow the cable and connector to be held very securely in the body. The T6S RCA accepts cables from 4mm to 9.5mm in diameter and comes with two reducers to perfectly match the diameter of your cable.
Product type | RCA Connectors |
Contact plating | Gold 24k |
Shell material | Aluminium |
Min/Max Cable diameter | Min : 4mm Max : 9.5mm |
Total length | 45mm |
Shell length | 30.5mm |
Shell diameter | 13.5mm |
Color | Matt black |
Quantity | Sold per pair (1 connector with red ring, 1 connector with black ring) |
Max cable diameter (mm) | 9.5 |
Mounting type | To weld |
Connectic | Male |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Average votes 5.0 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
jevgenijs S.
Jamel I.
Sébastien L.
christophe S.
