ELECAUDIO CAP-B RCA terminators Caps (Pair)
Reference : 6960
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 15-04-2025.
This accessory allows you to easily and durably protect the unused RCA connectors of your equipment from oxidation as well as dust.
Unused connectors after a few years of exposure to air, light and dust have a tendency to oxidation, accumulation of dust and deterioration of tackles.
Grâto these useful plugs, you improve the lifespan as well as the design of your equipment.
CThe cap is also an effective barrier against micro-electrical pollution (EMI / RFI).
The insulation of the RCA connector thus protected is total, the dust does not penetrate the device, its lifetime is prolonged.
Features:/ Strong>
  • Construction: metal color Black
  • Continuity between hot spot and ground
  • Bypassing
  • Max. Diameter: 12.5 mm
  • Maximum length: 28 mm
  • Packing: one pair
https://www.audiophonics.fr/images2/6960/6960_ELECAUDIOCAPB_1.jpg
https://www.audiophonics.fr/images2/6960/6960_ELECAUDIOCAPB_2.jpg
Also available in Black
https://www.audiophonics.fr/images2/6959/6959_ELECAUDIOCAPS_3.jpg
Mounting typeTo connect
Max panel thickness (mm)N/A
Contacts Plating (Connector)N/A
2 reviews
Great.
Does what it says on the box. Keeps rca plugs from oxidising. I can't comment on noise reduction as I don't have that problem in my system.
This review has been posted for ELECAUDIO CAP-B RCA terminators Caps (Pair)
Court-circuitant
C'est bien précisé, les caches sont court-circuitants. Ne pas utiliser sur les sorties des appareils. La pin centrale se dévisse, on peut donc dans ce cas l'utiliser en entrée et sortie.
