ELECAUDIO ER-106 Inlet RCA for IC Gold Plated (Pair)
Reference : 8156
6,90 €tax incl.
5,75 € tax excl.
RCA connectors ER-106 ELECAUDIO
Connectors high quality printed circuit
RCA connectors for stereo
These RCA sockets sold in pairs can be easily integrated with electronic circuits and ideal both for construction projects, improvement and repair of equipment.
The conductor is plated with 24 carats for optimum conductivity.
The capsule is made of plastic THERMORESISTANT to ensure high robustness while imposing a minimum weight for installation.
TypeRCA phono socket
Number of pieces2
1x Red
1x Black
ScrewingOutside
Body length14 mm
Height (excluding pins)13 mm
Total length34 mm
Total height24 mm
Panel Thickness max5 mm
Length of the base with thread20 mm
bore diameter of the housing12.5 mm
Stereo RCA and better signal
What DAC RCA choose
Best RCA connector
Best RCA socket
Mounting typeTo weld
Max panel thickness (mm)5.0
ELECAUDIO ER-106
Acheté pour réparer des fiches d'un PS audio Perfectwave.
Résultat parfait.
This review has been posted for ELECAUDIO ER-106 Inlet RCA for IC Gold Plated (Pair)
