RCA Plugs Stereo Gold Plated for PCB
This ELECAUDIO ER-110 RCA stereo socket is particularly suitable for PCB mounting. It has a special design with two long, angled contact pins and 3 fixing tabs, making it easy to mount on a printed circuit board. In addition, this base has a good manufacturing quality, with gold-plated copper alloy contacts ensuring good conductivity and excellent oxidation resistance as well as PTFE insulation.
Plug type | Stereo RCA |
Contacts material | Copper alloy |
Plating | Gold |
Insulation | PTFE |
Max panel thickness | 7.5mm |
Dimensions | 35.5 x 16 x 35mm |
Mounting type | To weld |
Max panel thickness (mm) | 3.5 |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
