ETI FR-TC07 Female Chassis mount RCA Tellurium Copper (Pair)
4.8 / 5
Reference : 11934
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 24-04-2025.
ETI FR-TC07 RCA Connector Tellurium Copper
RCA FR-TC07 terminals offer (as their big sisters do), the Phonopod, increased conductivity but also integrate new additions.
Competitors mostly use bases made of nickel, gilded brass or bronze / phosphorus alloys, with a limited conductivity often below 28% International Annealed Copper Standard (IACS), and thus diminishing the performance of the components to which they connect.
On the contrary, ETI takes a different approach, promoting the use of cof high purity Tellurium (more than 90% IACS) for its contact elements, to ensure optimum conductivity .. So the ETI FR-TC07 sockets can boast of giving a real scope to your music, guaranteeing you an improved listening.
The aim is a low self-inductance, the elimination of RFI reflections, unmatched frequency bandwidth, durability and easy installation.
KEY ELEMENTS
  • Lengths / masses of signals and return plugs as thin as possible to ensure better durability
  • Use of pure Tellurium copper to reduce inductive reactance, to achieve wider bandwidth.
  • Provides better response in high frequencies and therefore better sound.
  • Low-mass outer shell for transmitteran extremely fast ground signal./ Li>
  • Curved signal conductors to facilitate welding.
  • Brass nut, providing excellent vibration damping and EMI / RFI noise rejection screws on polymer thread.
  • NO use of nickel, brass, bronze to ensure maximum conductivity and better signal transfer.
Spacings FR-TC07
ETI-Research-FC-TC07-Female-RCA-cotation
TypeRCA terminals
Color codeRed Black
Materialcopper Tellurium
Max Thickness4.5 mm
Drilling diameter⌀9.7 mm
Length29 mm
Max diameter⌀15 mm
Mounting typeTo weld
Max panel thickness (mm)4.5
Contacts Material (Connector)Tellurium Copper
4 reviews
the best chinch sockets
***** these jacks show you how high quality cables Audience Au24 SX can sound *****
This review has been posted for ETI FR-TC07 Female Chassis mount RCA Tellurium Copper (Pair)
very expensive but very good product
Parfaitement parfaite
On sent la qualité de fabrication , installation vraiment facile avec l'écrou sur le devant.
Bon produit
Bien fabriqué avec un bon rapport qualité prix, facile à monter.
Pas de retour son le son, période de rodage nécessaire pour donner un avis objectif.
Quoiqu'il en soit c'est du cuivre pur toujours bien mieux que du laiton
